06-08-2017
04:59
05:58
FerdinandFitbit
06-08-2017
04:59
05:58
FerdinandFitbit
I was praying with my 4 year old and he was hitting the buttons on my blaze. As soon as we were done I noticed it was off and I can't get it back on?! Help please
05:56
07:41
06-08-2017
05:56
07:41
Hey @Dukeb! Great to see you in the Community Forums! 🙂
It could be that he accidentally got to the last screen which is where the settings are and manually turned off the tracker from there... If you press any button, the tracker doesn't come on? Have you tried to restart it? If not, you can easily do this by pressing the left and lower right buttons for 10-12 seconds. This will make your tracker to reboot. Also, putting your tracker in the charger could indicate if it's working fine or not so trying that would help.
Let me know if that works.
