Blaze won't turn on
My Blaze hasn't turned on now for about 4 months. I've tried everything in the forums, nothing worked. Even if you drain the battery completely and plug it in, it wont boot up logo just flashes, can someone help?
3 REPLIES 3
Hey @BigRicci112, it's great to see you here.
Thanks for troubleshooting this by yourself. Could you please confirm if you have tried the restart process? If you haven't, I recommend restarting your tracker by doing the following:
  1. Press and hold the back (left) and bottom buttons until you see the Fitbit logo on the screen. This should take less than 10 seconds.
  2. Let go of the buttons.
Let me know the outcome. Man Happy
Hey i tried the restart process
Thanks for the update @BigRicci112. Since the restart process didn't work, I've gone ahead and escalated your case to our support team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
Keep me posted. Smiley Happy
