02-11-2020
02:44
09:33
02-11-2020
02:44
09:33
My fitbit blaze can't switch on even the battery is full. It can only start when i reconnect to the charger but after a few hours it will off again and can never be started until i connect to charger. Anyone had experienced this problem? Any tips?
Best Answer02-12-2020 09:36
02-12-2020 09:36
Hi there @xsraven600, thanks for the details provided about your Blaze's behavior.
I was about to create a support case on your behalf, but I've seen you contacted our Support Team after posting here and that they have helped you with this.
I'll be around if you have any questions present.
02-12-2020 11:12
02-12-2020 11:12
Hi there, my blaze has a similar problem, it doesn't start even after full charge. Can you help?
Best Answer02-12-2020 12:13 - edited 02-23-2024 07:35
Hi there @NunoPais, welcome on board.
I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon!
Let me know if you have any questions present.
