11-02-2018
07:27
09:37
AlejandraFitbit
11-02-2018
07:27
09:37
AlejandraFitbit
My Blaze has stopped vibrating. The alarm no longer vibrates nor does the countdown timer when I use it. I have tried a reset (holding the left and bottom button); recharging it; and fully shutting it down using the settings. Nothing has worked.
09:38
08:21
11-05-2018
09:38
08:21
A warm welcome to the Community @Kriswills17.
Thanks for troubleshooting this by yourself. Upon checking with our support team, I was told that you have already created a case with them. I know they will be glad to help you out and provide you a solution.
Let me know if you need anything else. ![]()
