Best AnswerHello @SunsetRunner your wivves Charge HR will also count steps if she waves her arm around in the correct way. In fact every tracker on the market will do this. If the tracker is moved in a way that it thinks the movement is caused by walking, then syeps will be counted. It has no way of knowing why it is moving, it knows it is moving.
As for miles, have you checked amd set your stride yet? This is needed when the connected GPS is not being used.
Another qiestion, where you using the connected GPS, knowing this is needed to give you an answer.
Best AnswerBrush, the Blaze is off by 20-30% on distance/steps and we are awaiting a fix/help/anything from FitBit to address this problem.
