09-16-2016
14:53
17:41
DavideFitbit
09-16-2016
14:53
17:41
DavideFitbit
Is there a charging device for connecting the Blaze directly to a wall socket?
Best AnswerWelcome to the forums @camano-kid
Just use any usb electrical plug and put your Blaze charger into it. That is the only charger unit Fitbit sells.
Best Answer@camano-kid there are many electric plugs which have usb ports in them for people to charge a variety of devices. Any of those ought to do what you need, but there is no Blaze charger with prongs to go directly into the wall socket.
Best Answer@camano-kid most phones today come with a little box you plug into the wall, and have a rectangle hole in an other side that a USB wire plugs into to charge the phone. Your tracker a charging wire will happily plug into this hole also.
If your phone doesn't have this wall adapter, commonly called awall worst because it is a bump or blemish on the wall, you can go down to any Five Below, big drugstore, Target, or even 7-11, basically any place that cells phone accessories and by a wall charger.
This is what your looking for https://goo.gl/rleJLU
