08-09-2017 12:19
08-09-2017 12:19
The charging case for the Blaze is really hard to open. It is necessary to pry it open with a knife or find a place to grip it on both sides to push it open. It should have a gripping surface top and bottom, as well as a lip on the lid or matching grooves top and bottom that would allow easy opening and closing. The design seems to have tried to address the issue, with very slight inward beveling of the top and bottom, but it is inadequate. This is a big annoyance with an otherwise super product.
While you're at it, consider a less robust cord from the charging case--it is heavier than necessary and quite bulky to stow.
Best Answer08-09-2017 12:22 - edited 08-09-2017 12:24
There is a button on the side front (bottom half, opposite side from the cord) that you need to push to open (it will pop the top up).
08-09-2017 16:37
08-09-2017 16:37
So there is. Why in the world don't they tell you when you buy it? Thank you!
Best Answer08-22-2017 15:36
08-22-2017 15:36
Watch the video thats found in Fitbit youtube channel. Link below.
The cideo is also found in the document on charging. Link to help docs below, as help.
Look in the user manual, that's found in help. Link below
