06-16-2016 01:59
06-16-2016 01:59
Is there a way to charge for Blaze without removing the meter out of the frame? When I remove it (about 5 days 1 time) for a while, but now the clock does not fit the frame. When shaking hands'll watch face can be shifted.
Best Answer06-16-2016 04:19
06-16-2016 04:19
@950XL You can only charge it by removing tracker from the band.
Kelly | Oklahoma
Alta HR, Blaze, Flex 2, Charge 2, Charge, and Aria * IPhone 7+
Best Answer06-16-2016 08:58
06-16-2016 08:58
Its one of the Blaze's design flaws. I've noticed it getting looser over time as well. Only way to "fix" it is to buy another frame. Not sure if its because the frame is bending over time or the contact pads are getting worn.
Best Answer06-17-2016 09:07
06-17-2016 09:07
It's great to see you around @950XL, @MikeS1971 and @Kmransom123 thanks for stopping by and for the tips provided. I agree with them, the only way to charge your Blaze is by taking it out of the frame. I recommend checking this request where a charging cable for the tracker is being mentioned, you can vote for it and leave your comment.
Keep the stepping up! ![]()
