03-13-2017
04:45
09:23
03-13-2017
04:45
09:23
A warm welcome to the Forums @Godees. @gtschwartz and @Rich_Laue thanks for stopping by.
If your tracker is not displaying the correct time, I recommend changing your timezone to a complete different one, sync your tracker, put the correct time and sync again. To change the timezone, you just need to do the following from a computer:
1. Log into your fitbit.com dashboard and click the gear icon in the top right corner.
2. Select “Settings” from the drop-down menu.
3. Scroll down to the Time section and choose the time zone that best reflects your current location. You can also select 12-hour or 24-hour time display format here.
4. Sync your tracker to update your time zone.
Now, if you are having problems syncing, I recommend following the instructions provided in the Having trouble syncing? post.
I hope this helps, let me know the outcome. ![]()
