Compatibility of Nexus 6P
Hi I have the Nexus 6P and it's a great phone. When will the fitbit blaze be compatible with this device? Yes i can pair it but I do not get any notifications with the blaze such as texts and calls. Thanks.
Moderator edit: subject updated for clarity
3 REPLIES 3
A warm welcome to the Community @ctayah. Our team is hard working in testing every phone that might be compatible with Fitbit trackers. I recommend keeping an eye to our list of Compatible Mobile Devices for any update.
Keep the stepping up! Woman Happy
Hi,
Same issue, get the call notifications but no tex and no calendar with my Nexus 6P. When will it be available??? Have a Fitbit Blaze and would like to use all it funcionalities... 😞
It's great to have you in the Community @JeanBD! I'm glad to announce that your Google Nexus 6P is a supported device now. You should be able to receive call, text and calendar notifications in your Fitbit Blaze. Please make sure that you're doing this set up procedure
Hope this helps. Let me know how it goes.
