03-02-2016 19:17
03-02-2016 19:17
Best Answer03-03-2016 00:51
03-03-2016 00:51
Best Answer03-02-2016 21:38 - edited 03-02-2016 21:40
I realise you have probably done this but I'll mention it anyway, Have you turned on location service on the phone. I have the Galaxy S5 and it connects to mine ok. Just thought I'd post something, sorry if it sounds obvious ![]()
Oh and maybe Bluetooth turned on as well.
Best Answer03-02-2016 22:26
03-02-2016 22:26
Best Answer03-02-2016 22:45
03-02-2016 22:45
Just enabling Location from the dropdown menu should be enough. I've had a look at some other posts and other suggestion are to check the "Always Connected" option is on in the FitBit App itself. Another one that seemed to work was to have the Fitbit app actually running and not completely closed (running in background is ok)
You might also turn off your phone and restart it maybe something is blocking things I've also noticed on previous updates for the fitbit app a messgae pops up telling me an update was applied and restart of the phone maybe required.
Best Answer03-03-2016 00:25
03-03-2016 00:25
Best Answer03-03-2016 00:28
03-03-2016 00:28
03-03-2016 00:46
03-03-2016 00:46
03-03-2016 00:51
03-03-2016 00:51
Best Answer03-03-2016 04:32
03-03-2016 04:32
@Shawn24 wrote:
Just turned on notifications and Ta Da! It worked thanks. Now I'm not
pissed anymore.
Well done glad you got it going.
Best Answer03-03-2016 13:19
03-03-2016 13:19
Best Answer03-04-2016 17:13
03-04-2016 17:13
Hey rich. I am having the same issue with my S6 I just didnt quite understand your wording of "pull down stairs bat there is a teardrop that says location under it" are you refering to the quick tab location setting on the galaxy? I am not sure what I am doing wrong.
Thanks in advance.
Best Answer03-04-2016 19:50
03-04-2016 19:50
Finally got the connected GPS working on the Samsung Galaxy S5.
There is a call and text notification settings in the Fitbit phone app under devices. Just tap on the device, and you will see call and text notification settings. I turn on call, text and calendar notifications by selecting which app you want to use for each notification.
And you also need to turn on the notification on the watch, swipe down from main screen.
Hope this helps.....
Best Answer04-09-2017 08:59
04-09-2017 08:59
I have a blaze... and I've gone for a run and a bike both times it synced with phone and started and then disconnected... it's really disappointing... any suggestions... it's synced, I visually confirm before starting... and my stats don't show (which is why I got it and traded in my running watch)... yesterday's run only registered my first km... 😡
Best Answer04-09-2017 12:49
04-09-2017 12:49
Yes @cc whim connected GPS uses the notification services.
I find on my S5 I need to Swipe unwanted apps out of memory to free up enough space.
