11-20-2017
04:50
06:43
11-20-2017
04:50
06:43
Hi there @Ray67. Great to see you in the Fitbit Community Forums! 🙂
It's strange that your Blaze is counting steps when you're not wearing it... ![]()
Is this happening at a certain time as during the night for example? Are you leaving your tracker somewhere exposed to vibrations that could make the tracker to move/vibrate and detect that as movement as a fan station or something similar? Also, are you by any chance logging activities manually? This could be another reason for your dashboard to show steps for a time you didn't wear your tracker but logging it will make those steps to show up.
If none of the above applies, you could try restarting your tracker. You can easily do this by pressing the left and lower right buttons for 10-12 seconds. This will make your tracker to reboot and hopefully, this will stops happening.
Let me know how it goes!
tried re-starting tracker but still recording steps even when tracker has been turned off all day
