12-28-2017
09:52
06:13
AlejandraFitbit
12-28-2017
09:52
06:13
AlejandraFitbit
Is there a way to have the battery display the percentage remaining like on the Charge 2. I have noticed that there are two settings that the Charge 2 has but the Blaze does not. The icon of the battery in the upper left corner of the screen does not really help me so that I can make sure I have the Blaze working for me. If it dies on me than I cannot be recording my progress.
Thank you for your help.
12-31-2017 06:16
12-31-2017 06:16
A warm welcome to the Community @Angela11.
Thanks for this suggestion. I recommend taking a look at the New Battery Icon for Blaze - Percentage % request and check what are our plans regarding this idea.
If you need anything else, do not hesitate in posting it. ![]()
Best Answer11-04-2020 08:11
11-04-2020 08:11
On the app, pull down on the screen to refresh.
The Blaze will display the percentage for a few seconds while syncing.
I sync twice, to make sure I'm looking at fresh data.
