07-18-2017 15:31
07-18-2017 15:31
I just got my Blaze off Amazon and while charging the display works fine but as soon as I take it off the charger the display refuses to work I tried the reset function but nothing seems to work. Any help is much appreciated
Best Answer07-18-2017 23:20
07-18-2017 23:20
On the fitbit app turn on quick view
Best Answer07-19-2017 04:50
07-19-2017 04:50
Welcome to the Community @SpencerB and @SunsetRunner thanks for stopping by.
If your tracker is not displaying, I recommend restarting your Blaze. Also, if you tap your tracker's display does it illuminates or not?
Hope to hear from you soon. ![]()
