Naively, I bought a Fitbit Blaze thinking that it would work. Well, it does. Sort of. Sometimes. When it feels like it.
Yeah, I know, I'm running a watch that isn't on the list (Kogan Agora 6+), but I did finally manage to get it set up and synching. Then it stopped. Then it started again. Then I had to reset everything and start again. Over and over.
Sometimes I can watch my steps tick over as I'm walking. Other times I have to spend half an hour trying to get things to synch up.
It doesn't even make a good watch. Took it off for a few days as I was not in a position to use it and I put it back on this morning to find that it's about an hour and a half slow and four days behind.
If I was asked to rate this watch, I'd have to give it two out of five. If that. When it works, its good, but I don't think I'm expecting too much when I expect it to work all the time and not have to fight with it for half an hour every time I want to synch it to the phone.
I'm really sorry this is happening. But it does not sound like its setup correctly
Set up
http://help.fitbit.com/articles/en_US/Help_article/1873
It really needs to sync to be accurate as well and it does not sound like you are doing that.
Let us know!
Wendy | CA | Moto G6 Android
Best AnswerWell it looks like I should have done more research before buying the Fitbit. I did, obviously rather naively, think that, being a Bluetooth device, and my phone having Bluetooth, it would work. I could also believe that I might have erred in the setup if it refused to work at all. But when it sometimes works perfectly and then stops working, then works in a sort of a fasion, then... (you get the idea), I am slightly disinclined to think that it's due to a setup issue. Unless the app or device is prone to randomly changing its settings, that is.
