I walk a pretty consistent route that measures almost exactly 3 miles. My Blaze typically reports anywhere from 2.9 to 3.1 miles and about 7000 steps, which I was fine with. However, I've had it occasionally measure far less distance than it should. Today for example it measured 2.66 miles and only about ~4450 steps. Here are the various distances I've gotten for the same exact route over the past couple of weeks:
Any ideas what's going on here? How is it possible that it's recording the same route via GPS but giving different distances?
I haven't changed any settings on the device.
03:16
09:48
01-01-2017
03:16
09:48
A warm welcome to the Forums @pswoap. Thanks for the screenshots. Can you please tell me how are you logging these activities? Are you logging them manually or using the exercise option on the Blaze or SmartTrack? Personally, I recommend using the smarttrack feature to register your activities since it do it manually, also, please check your stride length, that all of your information is correct.
To measure this do the following:
To adjust it using a computer: click the gear icon in the top right and go to Settings > Personal Info. The stride length fields are in the Body Info section. If you use the Fitbit mobile app, go into the app and turn off Set Automatically under the Stride Length setting.
Hope this helps, catch you later. ![]()
