After trawling hundreds of forums amd help chats for a solution to my Fitbit Blaze /Samsung Galaxy S8 bluetooth notifications with no luck, I finally tried the following and it WORKED! (28th December 2017).
All calls, messages, calendar notifications now come through. I made sure all notifications were switched to on in the Fitbit app beforehand.
1. On your S8, go to Settings > Software Update > Download updates manually
2. Download all Android updates and install.
3. Phone will reset and update all apps on a green screen- takes 5 mins or so
4. Problem solved - send a test notification from the Fitbit app and it should work.
*N.B. this was my second Fitbit Blaze as the first didn't charge when plugged in
Good luck!
Glad you got it fixed and this should help others having the same problem.
So thanks for posting!
Wendy | CA | Moto G6 Android
Hello there,
I followed your instructions, however my phone tells me I already have the latest updates...
This is a screen shot of what I get when I select "download updates manually"
Let me know if this is the same version as yours.
Best AnswerMy current updates are:
G950FXXU1AQK7/G950FEVR1AQJ1/G950FXXU1AQK7
It only worked for me after doing this, if you have the same updates it may be something else?
Best AnswerHey there,
Thanks for the reply! It seems we have different updates.
I guess I will either have to wait for it to become available to me or find a way to download it.
Cheers!
Johnny Ray
My Blaze was fixed in the same time frame as yours, but stopped working a week later. Is yours still working?
