Hi there,
Just wondering if you have done a reset of your Blaze? Press in the left side and bottom right button at the same time and hold...you will get a notification message appear I believe but keep pressing them until you see the teal fitbit logo appear on the screen then release the buttons. It will then do a reset over the next few seconds. Hope it helps
