01-02-2017 03:39
01-02-2017 03:39
hi, Since the latest update (I'm using Iphone 6), my Blaze's battery drians within a day. It used to work fine for minimum of 5 days, so I figured it has been caused by the update? Thanks for your help. Cheers, Hans.
01-02-2017 08:49
01-02-2017 08:49
You can try restarting it: restart
Best Answer01-02-2017 10:25
01-02-2017 10:25
Thanks for your help. I'll try this tonight and let you know if it did the job! Best, Hans
