02-19-2018
05:35
06:12
FerdinandFitbit
02-19-2018
05:35
06:12
FerdinandFitbit
New Blaze, the battery charge lasts two days. Is that typical, usual?
02-19-2018 06:11
02-19-2018 06:11
Hi there @Rockroll. Great to see you in the Fitbit Community Forums! 🙂
I'm sorry to hear that the battery on your Blaze is not lasting as it should 😕 The battery on a Fitbit Blaze should last for at least 5 days with a regular usage. If it's lasting only two days, that's not the expected behavior on a new tracker.
I can recommend putting it to charge and once it's fully charged, take it off the cradle and put it on. Sync it and use it as you would normally do. Make sure to sync it frequently after this so that the battery levels are recorded on the app logs and once the battery dies, let me know so that I can take a closer look and then we can move forward with other options to get you back on track.
I'll be looking forward for your reply!
