11-05-2016 12:58
11-05-2016 12:58
My fitbit blaze is suddenly refusing to charge. I bought this in March this year. It has been working perfectly fine till now. The battery was in red last night so i had put it on charge. It has not charged and is now fully drained. I am assuming that there is something wrong with the charger. How long is the charger expected to last? It has been barely 8 months! Any suggestions ? Has anyone else faced this issue?
Best Answer11-05-2016 14:09
11-05-2016 14:09
@Anithra.pj If you have tried everything (including making sure it is in the charger correctly) you may need to contact support.
Are you using a phone "block" for plugging the cable into? If so, perhaps try another one to be sure it is not the USB block you are plugging into. (Hope that makes sense)
Kelly | Oklahoma
Alta HR, Blaze, Flex 2, Charge 2, Charge, and Aria * IPhone 7+
Best Answer11-05-2016 15:29
11-05-2016 15:29
Best Answer11-05-2016 22:06
11-05-2016 22:06
I use a third party charger that I found in here and ordered off Amazon that's directly plugged into my Xbox One console. I don't have that issue. Works well with those multiplayer death matches in Grand Theft Auto online.
