03-26-2018
21:46
08:06
FerdinandFitbit
03-26-2018
21:46
08:06
FerdinandFitbit
When I connect my fitbit the battery flashes, looks like it charging, however, when I disconnect it's dead.
Best Answer03-27-2018 08:05
03-27-2018 08:05
Hi there @Raphy. Good to see you in the Community Forums! 🙂
I'm sorry to hear that your tracker seems not to be charging correctly 😕
Now, I'd like to know if you've tried to charge your tracker on a different USB port or any other wall outlet. If so, does it do the same? Also, if you put it to charge, are you able to sync it while it's charging? When was the last time that your tracker was able to sync?
I'd love to have you back on track as soon as possible. I'll be looking forward for your reply!
Best Answer04-02-2018 03:18
04-02-2018 03:18
Yes, it does. Wont sync neither.
