07-01-2018
06:00
04:51
AlejandraFitbit
07-01-2018
06:00
04:51
AlejandraFitbit
Hi all Blaze users,
My Blaze was working perfectly alright until the day before yesterday when it had shut down due to low battery. When I had put in for charge, it was not charging and there was no other indication that it is connected to the power. When I press the left button on my device, it shows me the low battery symbol though and there seems to be no issues with the display.
How do I know whether the fault is in the tracker or in the charging cable? And any possible methods to fix this issue is greatly requested!
04:52
09:31
07-02-2018
04:52
09:31
It's great to have you here @KashyapSastry.
Thanks for troubleshooting this by yourself. If your Blaze isn't charging, I recommend taking a look at the help article Why isn't my battery charging? and follow the instructions provide there.
I hope this helps, let me know the outcome. ![]()
