04-18-2017 20:05
04-18-2017 20:05
I have not used my blaze in some months. Now that I'm trying to connect, sync and update NOTHING IS WORKING! I read somewhere to try to connect on your computer but when I tried it's asking me for a "dongle"? Which obviously I don't have or I'd know what that was. It's been "connecting" to my phone for the last hour and I don't know how to bypass this. I deleted the app and the device off the app and basically tried to start new when the device wouldn't update which brought me to this pickle. Anyone have any answers?
04-18-2017 20:55
04-18-2017 20:55
Welcome to the forums!
Try these steps on. Sometimes I have had to do it a few times
1) Restart your device
http://help.fitbit.com/articles/en_US/Help_article/1186/?q=restart&l=en_US&fs=Search&pn=1
In your smartphone, with your Bluetooth turned off,
1) Go to your Setting >Application Manager > Fitbit App
2) Clear Cache and Clear Data and Uninstall
3) Reinstall the app, and allow the app to turn on your smartphone's Bluetooth when prompted
In your fitbit app, go to your device, and:
1) Turn ON All-Day Sync
2) Turn OFF Always Connected
Check out the discussions boards! A lot going on and I'm sure you have some contributions as well!
Hope to see you around!
Wendy | CA | Moto G6 Android
04-18-2017 20:53 - edited 04-18-2017 20:56
@Yoguimonster first thing I'm going to assume is that the blaze has been restarted using the 2 button press, and the phone has been restarted.
Lets make sure the Blsze is at least 50% charged.
You say you removed the Blaze from your Fitbut axcount, but did you remove it from the phone? This is done through the phones Bluetooth settings screen.
Your right removing the Blaze from your account will not fix the sync issue whixh still exists.
Now the next thing i would try is a complete shutdown of the Blaze through its settings menu, and a shutdown of the phone.
There also is sime help at
Http://help.fitbit.com/q=setup
There also will be tips on comunication problems at http://help.fitbit.com/q=setup
04-18-2017 20:55
04-18-2017 20:55
04-18-2017 21:23
04-18-2017 21:23
04-18-2017 21:54
04-18-2017 21:54
Removing from my Bluetooth helped the connection process!! THANKS! It's now updating.... To be continued.... lol
04-19-2017 01:10
04-19-2017 01:10
I glad it is working @Yoguimonster.
Removing the tracker from the phones Bluetooth is usually tge third thing i suggest. For me if the phone restart doesnt work, i do a shutdown of the phone, when it comes to the Charge 2 ive never gad to go further.
04-19-2017 06:39
04-19-2017 06:39
