04-03-2018
08:19
12:06
FerdinandFitbit
04-03-2018
08:19
12:06
FerdinandFitbit
3 weeks ago my Blaze stopped syncing to my iphone. My Blaze is relatively new. Had it for less than 6 months.
I tried everything that was mentionned here, nothing worked.
I have contacted the fitbit support, all they could tell me was that they are "working" on the issue.
It's getting really frustrating. It's 2018 and this issue has been around since 2016.
Getting desperate
12:05
05:31
04-03-2018
12:05
05:31
Hi there @CarrMaly. Grea to see you in the Fitbit Community Forums! 🙂
I'm sorry to hear that you're having problems getting your Blaze to sync with your phone. Now, I'd like to know if you've made sure that your phone is in the list of compatible devices. If not, please check the list here.
Once you've verified that your phone is in the list of compatible devices, you can try to restart your both, your tracker and your phone. For restarting your tracker, you can easily do this by pressing the left and lower right buttons for 10-12 seconds. This will make your tracker to reboot.
Once you've done that, you can try to set it up as a new device. For this, go to the Account section at the top right corner on the Fitbit app and select the option that says "Set up a new device". Follow the on-screen instructions and once you're done, your tracker should be syncing without a problem.
Let me know how it goes!
Best AnswerIs there anything else I can do? I have read and tried all the solutions posted here. Nothing works. Do you have any other ways to fix this? tired of reading the same copy-paste standard response all the moderators are giving out.
Yes, it's really frustrating. 200+ for a faulty watch
