06-03-2017 03:50
06-03-2017 03:50
press all 3 buttons on watch and notification prompt should appear. Make sure it is on by touching the screen on the prompt then sync should work.
04:58
09:45
06-05-2017
04:58
09:45
A warm welcome to the Community @Ngatcha and thanks for sharing the steps you did to make your tracker sync again.
I just would like to know if you keep having inconveniences syncing your Blaze? If you do, I recommend following the instructions provided in the Having trouble syncing? post.
See you around. ![]()
