Hi @Sean2112 if you're under warranty and there is a problem with the charger unit, Fitbit might send you one. Customer support can see more on their end as to your charger still working. You try contacting them?
Fitbit customer support is doing their best, but right now be prepared for longer wait times. Please be patient. Support is limited by the number of representatives available at a given time and the hours of operation. Chat lines are open when they have live help.
USA: call (877) 623-4997
UK: call 0800 069 8505
INDIA: call 000 800 050 1057
IRELAND: call 01 691 7502 (country prefix: +353)
Other contact options:
USA: click
Canada: click for options
Hello,
As the subject states, my Fitbit will not charge. I put it into the charger and nothing happens. I am not sure if it is the charger or the device. I have tried different USB ports on my computer, and no difference.
Is there a way to know if it is the charger or device? I don't want to buy a charger if it is the device.
Best Answer@Sean2112 it's not under warranty at this point. Mine made it two years before it simply died on the charger. You might want to look at the new styles of Fitbit. The Versa series replaced the Blaze.
