02-25-2018
09:48
05:46
AlejandraFitbit
02-25-2018
09:48
05:46
AlejandraFitbit
I mistakenly got in the hot tub with my Fitbit Blaze. I realized after a couple min and took it off and dried it. It stayed on and worked until the middle of the night I noticed it was off. Now it won't turn in but the app says it's got a full battery and when I sync it still says it syncing. I have it in rice now but any suggestions?
Best Answer02-25-2018 10:21
02-25-2018 10:21
It should be in rice for at least 48 hours so it can totally dry out.
But I suspect its gone to Fitbit Heaven
Wendy | CA | Moto G6 Android
02-25-2018 12:36 - edited 02-25-2018 12:37
The app will only tell you the battery at the time off the last sync. I would leave it in rice as suggested and maybe stick it in the oven with the oven light on if you do not have a pilot light.
Just remember to remove if planning on using the oven.
Maybe a piece of masking tape over the control.
Or place in a sunny spot.
Best Answer02-26-2018 05:48
02-26-2018 05:48
Welcome to the Community @SunsetRunner, @WendyB and @Rich_Laue thanks for stopping by.
I appreciate your efforts in trying to fix your Blaze by put it in a bowl with rice. I would like to know if you keep having issues with it after following the instructions that our friends provided?
Hope to hear from you soon. ![]()
