06-08-2018 01:32
06-08-2018 01:32
My fitbit please will not sync and now it won't connect via blue tooth to my phone. Been on going since yesterday. Please help.
06-08-2018 01:45
06-08-2018 01:45
I would try restarting your phone and then restarting your fitbit using this procedure:
Give this a few tries as it doesn't always work. If it still won't sync after that then there are some more ideas to try in this help file: https://help.fitbit.com/articles/en_US/Help_article/1866/
06-08-2018 01:45
06-08-2018 01:45
06-08-2018 01:49
06-08-2018 01:49
06-18-2018 12:12
06-18-2018 12:12
Great to see you around @SunsetRunner and @SteveH thanks for stopping by.
I am glad to see here that your syncing issue has been resolved by doing the instructions our friend provided. If you need anything else, do not hesitate to post it.
Keep the stepping up!
06-22-2018 21:50
06-22-2018 21:50
I have tried turning off, restarting both phone and blaze but still says it can’t find my blaze. I have a iPhone 6s and have tried the help forums with no luck
07-29-2018 05:17
07-29-2018 05:17
Thank you. This process worked!
@SteveH wrote:I would try restarting your phone and then restarting your fitbit using this procedure:
- Press and hold the back (left) and bottom buttons until you see the Fitbit logo on the screen. This should take less than 10 seconds.
- Let go of the buttons.
- If your Fitbit Blaze, Fitbit Ionic, or Fitbit Versa doesn't work normally, use the instructions in How do I turn off my Fitbit device? to turn your watch off and on again.
