02-12-2017
09:38
03:22
AlejandraFitbit
02-12-2017
09:38
03:22
AlejandraFitbit
I live in a 4 story Georgian town house there are 55 steps to the top but the blaze Fitbit won't count them No!! As they have a flat break at 9.5ft 😡 On each level this is not fair!! Help
Best Answer02-13-2017 03:22
02-13-2017 03:22
A warm welcome to the Community @Emilyjones6. If you are having problems with the information that your tracker is registering, I recommend taking a look at our How accurate are Fitbit trackers? article. There you will find the way that the Blaze registers your floors and some reason why it is not being accurate.
I hope this helps, catch you later. ![]()
Best Answer02-25-2017 08:05
02-25-2017 08:05
I've solved this by raising my arm above my head at the top of the flight of stairs! For a particularly short flight you might need to bend down at the bottom and put your hand up at the top!
