03-12-2017
04:54
19:19
DavideFitbit
03-12-2017
04:54
19:19
DavideFitbit
When I have just been for a run for some reason my Blaze is not connecting to my phone to use the gps? Any suggestions ? I have had a few little niggles since the app was last updated.
03-12-2017 09:16
03-12-2017 09:16
I'm having the same problem lately. I had to get a new phone (Moto G4) and it synced up fine with the Blaze (I get text/call notifications and data transfer) but I have not been able to get the GPS to work with the Blaze at all. I've tried restarting the Blaze, restarting the phone, taking off WIFI, etc. but no GPS.
03-12-2017 12:43
03-12-2017 12:43
I get my GPS to work by restarting the phone.
03-12-2017 14:54
03-12-2017 14:54
So you select the exercise, say biking, then you restart the phone?
Thanks
03-12-2017 17:02 - edited 03-12-2017 17:03
@Michelle8979Welcome.. Location must be set on on your Phone. If I'm having connection issues I use MapMyRun as a test to see if GPS is functional.and GPS Status to ensure I'm getting a strong signal. This makes me confident the phone side is working.
In case you haven't found Fitbit's guidelines for GPS, here is the link..
03-12-2017 23:16
03-12-2017 23:16
If it doesn't connect I cancel it on the tracker, restart the phone, then set it up through the tracker.
Normally this is not needed if I restart the phone phone once a week like all Android phones need to be.
I also have problems if my memory is to full, I might have to clear out some apps.
03-13-2017 10:17
03-13-2017 10:17
Thanks, I'll try that next time.
