@MamiThy Have you tried changing the time zone to correct this? You can change it by going to:
https://www.fitbit.com/user/profile/edit
Be sure to sync after you change this
hope that helps~
Kelly | Oklahoma
Alta HR, Blaze, Flex 2, Charge 2, Charge, and Aria * IPhone 7+
Best AnswerI am also living in TURKEY, It is possible to change time zone but we need to choose another time zone instead of gmt+2 which means that we have to choose another country we are not living in. If possible could you change the default time zone setting for turkey (Istanbul) to gmt+3.
Best regards
Welcome to the Community @MamiThy, @bariscicek it's great to see you around and @Kmransom123 thanks for stopping by. In this case, I recommend selecting another time that is similar to yours. You edit your timezone by doing the following:
1. Log into your fitbit.com dashboard and click the gear icon in the top right corner.
2. Select “Settings” from the drop-down menu.
3. Scroll down to the Time section and choose the time zone that best reflects your current location. You can also select 12-hour or 24-hour time display format here.
4. Sync your tracker to update your time zone.
I hope this helps, see you around. ![]()
Best AnswerHi,
This is not correct approach. The correct one is, FitBit has to update their servers with Turkey new GMT decision. Please read the news..!
