03-28-2016 20:44
03-28-2016 20:44
Best Answer03-28-2016 21:52
03-28-2016 21:52
Yes - and I must say most disconcerting. Zombie heart rate would be my bet guess LOL. I called support and they are replacing my Fitbit for that issue and two other issues.
Best Answer03-28-2016 21:54
03-28-2016 21:54
Best Answer03-29-2016 07:54
03-29-2016 07:54
I've noticed that when I take the Blaze off, it displays the last known HR that was measured. Then after I Sync the app has no HR reading for this period of time. I guess it thinks I died.
03-29-2016 08:01
03-29-2016 08:01
Best Answer03-29-2016 08:47 - edited 03-29-2016 08:48
I have had two separate graph results, when I take it off to measure my blood pressure which is done 3 to 4 times per day (old fogie at this end), there is either a dotted line and this huge increase from when the dotted line ends and picks up again. Example, take it off, HR is at 65, dotted line, picks back up at 135. The Omron meter that I use has just measured my HR at a whopping 67, so 135, I think not, since the 67 was just seconds ago. The other scenario is the HR monitor does not stop working, just keeps chugging along, Blaze is off, heart rate is going up, up, up....either I am virtually exercising my tush off, or I am one very active zombie. Measure my BP, HR from Omron meter is 65, put the Blaze back on right after the BP measurement and....my HR was 105.....like I said one very active zombie. I have calibrated the Omron with my Physcians equipment, which included the HR and BP measurements, the Omron is accurate, Blaze, well....the jury is out yet.
Best Answer12-03-2018 13:02
12-03-2018 13:02
I got a Fitbit blaze about six months ago and noticed the heart rate is still tracking when I’m not wearing it. Strangely going up quite high over 100bpm sometimes, whilst not being worn. Anyone know how to fix it? Tried restarting it and resyncing it. Any help would be greatly appreciated.
thanks
Best Answer12-03-2018 13:10
12-03-2018 13:10
@TaylorT64 I would check the settings for the heart rate, when the Blaze off taken off the arm the heart rate and it's lights should be turning off.
If they don't I would try a restart of the blaze
12-03-2018 13:20
12-03-2018 13:20
Thank you this seems to be working now
