Hi,
I recieved my Blaze in July after using my Charge HR for over a year. I have been very happy with it until recently as I have noticed some strange things happening.
Has anyone experienced any of this before? Is there anything I can do? As of now I have not recieved the newest update that includes the new clock faces, reminders, etc. I really didn't experience problems like this with my HR nor the Blaze when I first got it so I'm at a loss.
Thank you 🙂
I have noticed the same issue with my heart rate. It usually doesn't get stuck very often. When it does get stuck reading 30+ bpm higher than it should I restart the watch and it works fine. Not sure what goes wrong. Hopefully a future firmware update fixes this issue. They must be working really hard at updating the firmware because there hasn't been a firmware update in quite a few months.
I haven't experienced that issue of the steps. Personally I'd see if it gets stuck at 4,999 only when you are watching the steps on the Today screen. Try hitting 5000 steps while not looking at it and see if it goes above that when you are not looking at it.
Freezing and then restarting is not a good sign. My Blaze maybe has restarted once or twice in its lifetime when I didn't tell it to restart. If it is very consistent, I'd call fitbit support. You should still be within the warranty window and if it is restarting, then you might need to get a replacement tracker.
Hope you get things working for you really soon.
Best AnswerWith so many complaints about the same issues it seems that Fitbit would push out a solution instead of treating each as an individual problem. I have tried resetting, turning the HR monitor on and off, and just leaving it off.. Nothing seems to reset it. I've been tracking with a Fitbit since April. For th last seven days my resting rate has been stuck at 74 instead of moving between 69 and 72 as has been normal. When I walk across the room it will jump to over 100, this can't be correct. I've given up on the stair count, neither the Charge HR nor the Blaze will accurately count stairs. I get a general idea of how many calories that I've burned, but given the many problems, this may not be entirely accurate, just overall an idea of where I am throughout the day as far as exertion and overall activity, not an accurate portrayal.
