10-16-2017 16:13
10-16-2017 16:13
I'm running into an odd situation with my Blaze.
The heart rate seems to work normally at all times including most exercise. But when I get my heart beating above 150 bpm the reading gets flakey. Up to 150 it's fine, but once i get to 150 it looses the heart rate & stops reading...then it reports sub 100, and slowly climbs back up to about 110 and hovers around there.
Today I tried it on a stationary bike, so that I could use the bikes heart rate monitor to compare. At the start they were about the same (around 5 bpm apart any time I checked), and then once I got to 150 the Blaze flaked out as described above. On the bike I got up to 165 while the Blaze was reporting 105. Then during the cooldown as my heart rate slowed, the Blaze finally got accurate again once my heart beat dropped below 120.
Anybody know what's going on or have any suggestions on how to fix this?
10-19-2017 09:05
10-19-2017 09:05
It's great to see you around @SunsetRunner. Are you making sure that you are wearing your tracker properly? In this post, our friend @FerdinandFitbit is providing some tips to properly wear your Blaze and obtain a better HR reading.
I hope this helps, let me know how it goes.
10-19-2017 09:05
10-19-2017 09:05
10-19-2017 14:43
10-19-2017 14:43
Hi @AlejandraFitbit. I've been wearing it properly for day to day use as described in that post. I'll try adjusting how I wear it during exercise and see if that changes the results. Will let you know.
Thanks!
10-23-2017 21:51
10-23-2017 21:51
Hi @AlejandraFitbit. I tried the suggested placement of the tracker 3 fingers up from the wrist during exercise and it seems to have done the trick. I was able to track my heartrate properly up to 165 bpm today on the stationary bike. Thanks for your help.
10-30-2017 06:08
10-30-2017 06:08
Those are great news @SunsetRunner, you are welcome!
I am glad to hear that your tracker is now properly registering your heart rate information. If you need anything else, do not hesitate in posting it.
Happy stepping!
