02-21-2017
09:48
18:37
DavideFitbit
02-21-2017
09:48
18:37
DavideFitbit
My phone is reading a heart rate and it not currently on wrist. I rebooted and not changes. Please help
Moderator edit: format
10:22
04:10
02-21-2017
10:22
04:10
Hi there @Annied04. Good to see you in the Community! 🙂
If you take off your tracker but you're moving it around, it could try to attempt to measure your heart rate. For that reason, I can recommend putting your tracker in the Auto setting. try changing your Heart Rate setting from "On," which means the heart rate tracker is always active, to "Auto," which means the heart rate tracker is usually active when you're moving.
For this, tap on your tracker at the top of the app. Scrolldown to "Heart Rate" and change the settings here. After that, make sure to sync your tracker and see how it goes.
Let me know if you need more help with this!
