Help with sync and bluetooth
Hi so I have had my Blaze for under a year.  June 7 it stopped syncing.  So I have tried everything and my mistake was I took off bluetooth and now it wont come up on my bluetooth. I have a toggle in the computer but it is not working on that either not sure what is going on there.  I have uninstalled and reinstalled the app but it is not coming up on the bluetooth.  I have a LG Stylo and it was working good not sure what happened. I don't know why it won't come up and sync. Help anyone thanks so much.
1 REPLY 1
It's great to have you here @rockinroxanne! Thanks for the troubleshoot that you've done. I was checking the list of supported devices and it seems that your LG Stylo isn't supported yet, you can use the app to log food and activities and sync your tracker using your computer.
If your Blaze isn't syncing with your computer, then please try this procedure
Hope this helps. Let me know how it goes.
