04-16-2016 05:13 - edited 04-16-2016 05:14
Hello everyone, to charge your Blaze I recommend plugging your charging cable into a USB port on your computer or other low-energy device. If necessary, you can use a UL-certified USB wall charger. Don't use a USB hub or battery pack to charge, and only use the charging cable that came with your tracker.
The Blaze has a rechargeable lithium-polymer battery. If your battery is low, charging fully may take one to two hours. To charge your Blaze:
To help you pick a good time for charging, note the following:
Hope this helps! 😉
It is health that is real wealth and not pieces of silver and gold! Share your story!
