12-30-2017
13:40
08:55
FerdinandFitbit
12-30-2017
13:40
08:55
FerdinandFitbit
How do you edit or delete foods on your meal/calorie page?
01-01-2018
08:53
09:43
01-01-2018
08:53
09:43
Hi there @Joebear. Welcome to the Fitbit Community Forums! 🙂
I can sure help you with this. If you're doing it from your mobile device, go down from the dashboard to the calories eaten tile. Tap on it, scroll down to your food log, tap on the item you'd like to edit or delete delete. If you'd like to edit it, you can do it from there and if you want to delete the item, then tap on the three little dots at the top right corner. From the options, tap on "Delete log" and that item will be gone.
If you're doing this from your computer, go to the Food Log section and here, look for the item you'd like to edit or delete. When hovering the mouse over it, an X will appear to the left side and you can delete it from there.
Hope this helps and anything else, I'm here to help!
