12-30-2017 07:19
12-30-2017 07:19
I’m trying to restart after using the shutdown button on the device, under settings. I thought that might sync the time to my phone. Time has been 1 hour behind. Also, I want to change clock face. I did that on app but it didn’t show up on device.
Best Answer12-30-2017 08:37
12-30-2017 08:37
@Sguthrie880 Holding in any button for a few seconds will turn the Blaze on, or put it on its powered up charger.
You will then need to do a sync to set the time, turning the Blaze off does upset the clock.
After changing the clock face the tracker needs to sync, stirring the sync the new clock face is installed.
Keep me updated.
12-30-2017 08:37
12-30-2017 08:37
Keep me updated.
12-30-2017 11:46
12-30-2017 11:46
10-16-2018 01:42
10-16-2018 01:42
, Dear All,
please help me to turn on my Fitbit Blazz i have turn of and now i couldn't turn on but back sensors is still on and blinking
Best Answer10-16-2018 01:56
10-16-2018 01:56
Dear All,
@Adeel22 wrote:, Dear All,
Best Answer10-16-2018 02:44
10-16-2018 02:44
Hold in the left button until the display turns on.
But since you say that the sensors are on, I suggest holding in both the left and lower right buttons.
10-16-2018 02:51
10-16-2018 02:51
