01-04-2017 11:31
01-04-2017 11:31
According to the Withings website my Blaze should interface with my Withings scale sending the weight info to it but I can't figure out how. I've been in contact with Withings and they said to contact you.
Thank you!
Best Answer01-05-2017 15:31
01-05-2017 15:31
It's nice to have you on board @CindyBra! There shouldn't be any interference because Blaze will sync everyday data to your Dashboard and Withings Scale will sync just your weight. Please make sure that you did this procedure to link the scale to your Fitbit account.
Additionally, have you had any issue while you've been using it?
Keep me posted!
Best Answer01-03-2018 15:03
01-03-2018 15:03
The link to that procedure is not working for me. It's bringing up an error.
Best Answer01-04-2018 15:35
01-04-2018 15:35
It's great to have you here @judoka209! Can you provide me with a screenshot of the error that you're getting? I tried to open the link and I was able to get the article, check it here Can my Withings scale link to my Fitbit account?.
Hope this helps! ![]()
Best Answer01-04-2018 19:05
01-04-2018 19:05
