01-07-2016 09:33
01-07-2016 09:33
Are there any photos with Blaze and Surge side by side or Blaze and Apple Watch side by side? I am just trying to picture how big it will look on my wrist. I currently have the Surge and would love to get a color screen with calendar notification.
01-07-2016 15:36
01-07-2016 15:36
@hytek369I was able to find the following picture of the Blaze next to an Apple watch and also some sizing charts so you can get a better idea of the fit. Hope you find these useful.
Blaze:
Surge:
01-07-2016 09:38
01-07-2016 09:38
I haven't seen any comparison photos but my feeling is that it's a little squatter but maybe a bit longer than the Surge.
Mike | London, UK
Blaze, Surge, Charge 2, Charge, Flex 2 - iPad Air 2, Nokia Lumia 925 (Deceased), iPhone 6
01-07-2016 15:36
01-07-2016 15:36
Blaze:
Surge:
01-07-2016 16:16
01-07-2016 16:16
This is awesome. Thank you so much.
01-07-2016 16:30
01-07-2016 16:30
@hytek369 My pleasure!
01-07-2016 18:26
01-07-2016 18:26
01-08-2016 11:28
01-08-2016 11:28
@SunsetRunnerNo idea.
01-15-2016 10:30
01-15-2016 10:30
@IW1206MT wrote:
Any idea if that's a 42mm Apple Watch?
@SunsetRunner From the specs the Blaze is slightly larger than the 42mm Apple Watch. Here is a picture of Blaze next to 42mm Apple Watch:
http://versus.com/en/s/size/apple-watch-vs-fitbit-blaze
So it looks like the Blaze is a little bigger than 42mm Apple Watch and a good bit bigger than 38mm Apple Watch.
01-15-2016 14:43
01-15-2016 14:43
@bbarrera That's a super cool comparison tool! Thanks for sharing.
01-17-2016 13:33
01-17-2016 13:33
my biggest issue with the Surge is that it doesn't fit comfortably under a work shirt, I find myself constantly taking off the cuffs whenever I need to look at it. Can't tell from those pics if the Blaze is a bit flatter than the Surge, but thanks for posting it's a great start.
01-19-2016 08:18
01-19-2016 08:18
@mnmio15 Blaze is consideraly flatter than the Surge, and (in my opinion) fits better under a long-sleeve. This is due to the exclusion of GPS.
01-27-2016 09:08
01-27-2016 09:08
01-27-2016 09:26
01-27-2016 09:26
01-27-2016 10:25
01-27-2016 10:25
Consider this "best of both worlds" scenario- Use the Surge for days you're running/doing high-intensity activities and use the Blaze for every day wear with some exercise spinkled in.
01-27-2016 10:29
01-27-2016 10:29
When your girlfriend purchased the tracker from Fitbit, and still has the receipt it can be possible for her to get a full refund*. Of course this means being without a tracker until the Blaze comes out.
Only thing to do.. Try telling your girlfriend..
* Feel free to check out out http://www.fitbit.com/returns
02-20-2016 05:18
02-20-2016 05:18
02-20-2016 05:50 - edited 02-20-2016 05:51
When multiple trackers are linked to the account, it's as easy as just wearing the tracker you wish to use. The magic happens automatically.
Of course best to wear / use one device at a time.
02-20-2016 12:39
02-20-2016 12:39
The magic happens in the cloud after the Fitbits are synced, the sent knows which tracker was moving ate which time, then uses the active tracker.
Pretty neet!
02-22-2016 13:09
02-22-2016 13:09
I've had challenges switching devices, had the flex and charge hr. Finally gave up and just have the charge HR of course i preodered the blaze and it just shipped. So... I'll be giving it another go.
I use the IOS app and found that I would lose steps if I tried to wear the flex all day and switch to the charge hr for a night run for example..
02-23-2016 11:27
02-23-2016 11:27
My Blaze just arrived to replace my Charge HR. Loved the CHR but the Blaze screen is amazing.
The Blaze had about 50% on the battery out of the box and it will need to update the software after it connects to your phone. I have had the Surge in the past but it was just plain ugly where the Blaze is not so bad.
