The only solution FitBit has offered is to contact tech support. If your product is still under warranty, they'll help but if not, they'll only offer a 25% off. The former Blaze watches received an update that has essentially made everyones watches useless and won't hold a charge. This is something FitBit did but will not correct it or offer reasonable solutions for their customers.
Best AnswerHello to you all. I got involved around Aug-Sept last year had problem with the step program which it was confirmed then a replacement has been sent. So far been checking with support regarding the battery it has been doing fine. Now I had let completely drain on this last time, which at this time have it charging. I had it charged a week ago Monday morning, and charged it this morning. May I asked in what settings you have been using? Had not tried the GPS system yet, I guess I alway not reached the 10,000 steps every day so have you all been pushing it so to speak?
Best AnswerHello if I may make a suggestion it may apply to your situation. When I got the replacement on my tracker I turn everything off, and allow to drain completely. This is what I was asked to do by support. Then charge it up but also do you have the current update for it? If I remember correctly when near the Versa came out another update came for the blaze?
