01-02-2017
14:50
13:16
DavideFitbit
01-02-2017
14:50
13:16
DavideFitbit
I purchased a Blaze, it would not charge. Chatted w/ tech support for over an hour, and couldn't get it to work. Returned it today for another Blaze, and same thing. It will not charge. When I put it in the carriage (and it's in there correctly!), the battery icon does not show. I've reset it. Plugged it into 2 different computers and 2 different phone charges, and nothing. I can't set it up because the battery is too low. This is unbelievable. Guess I am returning this one as well. What the heck is wrong with the Blaze and not charging? I see a bunch of posts on here about the same thing. How disappointing!
Moderator edit: format
Best Answer01-02-2017 15:51
01-02-2017 15:51
@JenniferJ73 Have you set your Blaze up? Has nothing showed on the screen? Until you set up the tracker, a battery indicator will not show. Only the Fitbit.com/setup message.
How long has it been in the charger? Perhaps leave it a while longer, and see if you can do the setup after that.
Kelly | Oklahoma
Alta HR, Blaze, Flex 2, Charge 2, Charge, and Aria * IPhone 7+
Best Answer01-02-2017 16:25
01-02-2017 16:25
