Hello @ImFit, is this your first fitbit?
What stuff are you seeing on it, actually where are you seeing it.
On the Blaze you can only see todays data, which would not be their stuff.
When you do set the tracker up it will reset their settings replacing it with your settings.
Best AnswerHi @Rich_Laue yes this is my first and I'm seeing it on my app it's showing steps stairs and calories burned and I haven't even put it on yet
Best AnswerHave you set it up to your account yet? This setup procedure will reset everything to your settings.
Best Answer@Rich_Laue Yes I set up my account and even deleted the device and re added it and the same info is still there
Best AnswerI still have 2 questions
Exactly what info is of concearn?
You say it is still there, but i have no idea of what your looking at?
The tracker can only show one day at a time.
Welcome to the Community @ImFit! It's totally fine if you're seeing calories burned because those are your BMR. However, if you're still seeing steps, floors and any other data than calories burned. You can delet it by logging driving as an activity:
Additionally, are you seeing badges in your account? Are you seeing information just from today or from other days as well?
Thanks for your advice @Rich_Laue!
Keep me posted.
