Welcome to the forums!
Are you relying on Smart track? If so try using the exercise function instead. This way you will make sure to capture it.
On the Dashboard you can set up 7 exercise shorts cuts. Once it syncs you will see them on the device it self. Select the one you want Push in the button to start. When done Push in the button again to stop.
The manual is here and can help a lot
https://staticcs.fitbit.com/content/assets/help/manuals/manual_blaze_en_US.pdf
Looking forward to seeing you around the forums!
Wendy | CA | Moto G6 Android
