Hi, I'm just frustrated because there must be an easier way to do this, and I'm missing it. I know my stride length on my elliptical is 18" and the number of inches in a mile is 63360. If I divide that by 18, I come up with 3520 strides to make a mile (or 1760 rpm). Or I can go by the following which is easier:
"The stride of most elliptical machines is less than that of a normal walking or running stride length, which is why it takes more strides on an elliptical to reach a mile. It takes about 2,000 steps to walk a mile. You can estimate the number of walking-equivalent steps you take when exercising at a moderate pace on an elliptical machine by multiplying the number of minutes you exercise by 203. For example, training on the elliptical for 30 minutes equals about 6,090 steps. This is useful if you’re tracking your steps throughout the day using a pedometer and the device doesn’t track steps effectively when training on the elliptical."
The problem is putting the info in MANUALLY, because the way the dashboard is set up is not very conducive to this. Today I did 35 minutes of moderate activity so multiplying by 203 I got 7105 steps. You can't put that in, ANYWHERE. I'm either going to be rewarding myself HUGELY or kind of screwing myself over re: daily steps. If you go to the Dashboard and put in the time, it automatically gives you the distance and calories burned, and it's not accurate. I'm no Einstein, but I also don't think I'm getting this 100% wrong either.
