05-10-2017 19:46
05-10-2017 19:46
Tha batterie if my blaze was over , it turned off .. I charged it for more than 3 hours and it's still off ...can't turn it on .
I bought it a less than a month ago .. please help!
05-10-2017 20:40
05-10-2017 20:40
Welcome to the forums!
Please clean the contacts
http://help.fitbit.com/articles/en_US/Help_article/My-tracker-s-battery-isn-t-charging/?q=not+chargi...
Then Do a Restart
http://help.fitbit.com/articles/en_US/Help_article/1186/?q=restart&l=en_US&fs=Search&pn=1
Also See this thread for charging best practices. If you are not charging it correctly you could be damaging the battery
https://community.fitbit.com/t5/Charge/Fitbit-charge-battery-problems/m-p/1323307#M53291
If it doesn't help Contact Support
http://help.fitbit.com/?cu=1
Hope to see you around the forums!
Wendy | CA | Moto G6 Android
05-10-2017 21:12
05-10-2017 21:12
@Cristinamiranda not sure how your charging, i suggest using your phones charger. The computer can only pull at best 500MA, this could take 4-5 hours before there is enough power to turn it on. Alsi when a computer goes to sleep, the charging either stops or gets greatly reduced.
Using a phone charger with my dead Blaze, sometimes takes 2 hours before i see any life.
05-11-2017 05:11
05-11-2017 05:11
A warm welcome to the Community @Cristinamiranda, @WendyB and @Rich_Laue thanks for stopping by.
If you are having problems with your Blaze battery, I recommend following the instructions provided in this post.
I hope this helps, let me know the outcome.
05-11-2017 06:47
05-11-2017 06:47
05-12-2017 04:35
05-12-2017 04:35
Thanks for the information @Cristinamiranda and for troubleshooting this inconvenience. Please keep an eye on your inbox for further instructions.
See you around.
05-12-2017 04:44
05-12-2017 04:44
I'm having the same problem. I've had my Blaze for about 10 months. Worked great but I just stopped wearing it for about 5 months. Now I've cleaned it, plug it in and still no charge. Bummed!
05-12-2017 04:49
05-12-2017 04:49
Welcome to the Forums @VenaJenkins and thanks for the information.
If your Blaze is not charging, I recommend following the instructions provided by our friend @WendyB in her previous post.
Hope this helps, see you later.
