Not connecting
I am setting up my Blaze for the first time to my android. I have entered the code and now it just says connecting and not actually doing it. I have left it for a good 10 mins and have also tried again. Any ideas what I can do. Thanks
4 REPLIES 4
A warm welcome to the Community @Kamorris and @SunsetRunner thanks for stopping by.
Thanks for troubleshooting this inconvenience by yourself. I would like to know if you keep having problems setting up your tracker? If you do, I recommend restarting your Blaze and follow the setup procedure one more time from your phone.
I hope this helps, let me know the outcome. Smiley Happy
Thank you for responding, it's fine e now, it just a while to connect but up and running. However I don't seem to get notifications from calls and texts even if the phone is next to tracker. Could you help with this.
Thanks
Thank you for responding, it's up and running now, it just took a while to connect x
