Best AnswerTried a restart a couple of times?
09:02
07:29
10-26-2016
09:02
07:29
Hey guys @SunriseRun1250 @daunh, good to see you around1 🙂
@daunh, how long is it taking for your tracker to drain the battery completely now? The battery on the Fitbit Blaze should last at least 5 days with a regular use so if it lasts less than that, there might be something going on with it.
I would recommend following @SunriseRun1250's recommendations and also, fully charge your tracker. After the battery is full, continue to use it as you would normally do but make sure to sync your tracker frequently during the day. That way, if the battery runs out faster than it should again, you will be able to get in touch with the Support Team and they will be able to confirm in the logs that your tracker might not be working fine and will be happy to get you back on track.
Let us know if you need any more help!
